SPC force objective in optimization with multiple load steps
I tried to run the following optimization:
- 2 responses: spc force and displacement
- 2 load steps: ls1 (linear static) and ls2 (NLGEOM)
- displacement constraint (for linear static load step)
- minimize spc force as objective (for NLGEOM load step)
- design variable: thickness
However, when I run the optimization, I get the following error:
DRESP1 3 is not referenced from within a static or an MBD SUBCASE.
This type of response must be specified from within a static or an MBD
SUBCASE.
When I then change ls2 into a linear static load step instead of a NLGEOM, the optimization works. Therefore, I was wondering how to run the optimization with a NLGEOM load step. Is that possible?
Thank you!
1 - 3 of 31
