I'm working on a project to simulate a simple crash simulation. Am I able to import data (such as SolidWorks) to simulate in RADIOSS? If not, what software do I need to use?
I'm not sure that you can import data from SolidWorks directly. But you can export to *.stp to import into HyperMesh.
Radios is the solver.
You will need to prepare the mesh and setup the material,properties, and boundary conditions to run the model deck in Radioss.
You can do the preprocessing with HyperMesh.
