hi,
im running into some issues when i add pretension to a rod element. i end up with a infinite displacement. I am hoping for the rod + the spring element to dampen the load to finite value. is there something im missing with my setup?
CROD has no bending stiffness so both ends of it work like pin joints, your model is a mechanism (in .out file shows that compliance is negative or large, it means model is lack of constraint
