I have the top and bottom surfaces of a cylinder defined in one component and the shrink wrap mesh of the whole cylinder in the other component. I need those surfaces to apply loads and boundary conditions to select the elements on which the loads are to be applied. If I try to select these elements by plane, not all of those elemets on that surface get selected. How can I use those surfaces to select the elements inside their boundaries?
