I am establishing a topology optimization, the aim is to attend 50% of the original masse of my mechanical part.
I used this formula to calculate volume fraction:
Volume fraction = (total volume at current iteration – initial non-design volume)/initial design volume= 0.082
I put 0.082 as upper bound for volume fraction constraint and for Isosuface threshold parameter in Ossmooth when I export this file.
The problem that I am not getting a 50% masse of the original solid at the end.
Should I put 0.082 or 0.5 threshold parameter in Ossmooth?
I am I doing something wrong?
Thank you.
