I have created a step file in which I had kept measurement in mm. Now if I use consistent units N,m,s,Kg. What happens to the imported geometry?
I have created a model using Siemens NX, while creating that particular model I used mm in the whole model. Later I saved it to step file and imported the same in hypermesh.
Now I understand I need to maintain consistent units so does it mean I need to now keep every unit in hypermesh in mm only.
