How i can resolve this problem? A fatal error has been detected during input processing:
*** ERROR # 4021 *** Material defined by MATHE (MID = 1) is not supported in NLGEOM, IMPDYN and EXPDYN subcases.
Hi Jungerman,
Need a workaround with the material defined. Can you share the model file?
@jugerman can you run NLSTAT with Large displacement instead of NLGEOM and check if your anslysis processes?
