I am trying to do a welding simulation in optistruct. I want to simulate a moving heat source over a period of time. How can i do it??
This is a linear transient heat transfer analysis case.You could refer to the below online help tutorial or download free on thermal analysis with OptiStruct using below link.
OS-T: 1090: Linear Transient Heat Transfer Analysis of an Extended Surface Heat Transfer Fin
https://altairuniversity.com/free-ebook-thermal-analysis-with-optistruct/ (Refer chapter 7 of eBook)
Thank you so much for this information. But in the above analysis, there is a time dependent loading on a single point. I need help for activating loads at different nodes along the weld, at different time intervals. can you please suggest something about this.
