I've started to explore the Squeak and Rattle Director. I have some result non-compliance while using acceleration as dynamic load function. The defined e-line is of Rattle type.The relative displacements of each node pair I get seem strange (see attached file). I don't have this problem using any other type of dynamic load (force, displacement, velocity). What can be the reason of this issue?
Thank you,
Best regards
