Constraints in HyperMesh
Updated by Altair Forum User
Hey guys!
I would like to do a linear thermal analysis. I would like to catch the proper behavior of my system that's why I used constraints in the thickness direction of a thick aluminium plate.
The plate should dilate in all direction but the top side of it.
How can I apply such constraint which allows the displacement of a node in the positive direction of an axis and obstructs the DoF in the negative direction?
Should I use some kind of contact for this purpose?
Thank you for your time and your answer in advance!
Kind regards,
Imre
1 - 1 of
11
Yes, use contact.
