create a Rigitwall Linear static analysis
Updated by Altair Forum User
Hello @ all,
i need to create a Wall in a model, which only blocks the translation in negative x direction and allows to translate in positive x direction.
I read, that this is possible by using Gap elements including PGAP property. The only problem is, that i have to lock 659 nodes an thats too much to constrain node after node.
so i need a possibility to realize such a constrain without doing this for each single node.
greetings
Christian
