hi
i am simulating the 3 point roll bending is there any keywords to find the nonlinear deformation
Hi Shrinaath
Did you mean the plastic strain?
Thanks
Hi Pranav
yes i am not getting plastic strain in post processing but i am getting von mises stress i have selected anim/elem/EPSP
i used mat36 material law and assign the plastic stress strain curve
is that i have selected wrong material type?????
Hi @Shrinaath
the issue was with solid property parameter Isolid=12 which is an obsolete formulation and does not output plastic strains so Isolid=17 or 24 should be used instead, as explained in the other thread.
