Required force for enforced displacement
Hey, I am trying to simulate some potential infill structures for 3d Printing. It wasn’t so easy to get a force equally distributed on the Structure, so I decided to use theenforced displacement analysis.
As a result, I am trying to get the force that is needed to get the implied Displacement. It would be even better to get a stress-strain diagram for each structure.
So far, the simulation is working but I am not sure which control cards or other settings I have to select to get the results I need.
Thanks for your help.
Thank your, for your fast response.
I have selected the GPFORCE card, but I am not getting a result. I suppose that I selected the wrong settings for the card ( I just started using Hyper Works).
In HyperView I selected the FBD and got an error message which is shown below.
0 -
Can you try with H3D format and leave form and peak to default.
0 -
I am not able to select the format you suggested. Could it be that this is a limitation of the student version?
0 -
.<?xml version="1.0" encoding="UTF-8"?>
Please make sure to set Advanced math template while loading result files in HV
