Hi!
If I add a rigid shell object with around 2000 trias to my simulation in order connect two components, would this slow down my simulation much? Or does a rigid object not really has influence on my computation time.
Best, J
Hi! If I add a rigid shell object with around 2000 trias to my simulation in order connect two components, would this slow down my simulation much? Or does a rigid object not really has influence on my computation time. Best, J
@jowidmer
It does affect the time step of your simulation.
Hi Prakash,
Ok. It only affects my time step. But it does not affect my computational time (time per time step) a lot?
Best, Jonas
TIme step and also simulation time as well.
