Hi everybody,
I try to simulate the contact between two mating gear by applying a force on a tooth and locking the center of the gear.
Using Optistruct to solve the equation the solution is (as showed in the attached) a deformed gear, deformed 2 teeth after the one with the load applied; I impose the value of 10 at the force and set the steel properties to the gear (as you can see from the Hypermesh file atached).
Someone can halp me understand why it gives me such a result?
Thanks in advance
