Hi everyone,
I want to set up 2mm/s as a load.
How could I do this?
Best regards,
Konstantin
what kind of analysis are you doing?
I would like to simulate a compression test with Optistruct.
Your case seems to be a nonlinear buckling (nlgeom) analysis
You can set total movement to SPCD LOAD regardless velocity (confirm there is any dynamic affect at 2mm/s speed?)
