I am analysing a birdtrike. I am using student version. The problem is that I can`t select the master and the slave because appears this issue in the screen : 'the component does not exist in the database'. How Can I resolve it?
Thank you very much.
there was no contact interface defined in your model.
For more details refer to a similar example:
RD-E: 4900 Bird Strike on Windshield
Yes, because I can`t define it. When I select the components to define the interface I see in the screen ' the component selected does not exist in the database' So I can´t define it. What kind of problema could be?
This is strange- I am able to set up a type 7 contact interface without problems on my end. Which version do you use?
