I did the frequency response analysis and saw contours of acceleration in hyperview. The results keep on changing. I want to see the final maximum distribution of acceleration over my model (for a particular frequency). How do I do that?
Hi Mayur,
Could you please explain what do you mean by changing?
Try to use a fixed scale for the legend. In contour panel, you will see Edit Legend, Click that and use type as FIXED SCALE and check if that helps.
