I have simple question: Is there a way to start a Radioss-simulation via Dos? And how?
Best, J
Hi J,
Please go through the attached document.
Cool! That works:
dos_command : 'C:\Program Files\Altair\2017\hwsolvers\scripts\radioss.bat' -both -nt 6 'C:\Users\<<username>>\Desktop\Results\ExampleModel.rad''
Is there also a way to stop it similar to the stop command you can send from the radioss gui? Or is the only way to shut down the process.
Use Ctrl+C to terminate the run.
