Here i attached files, My question is how to i represent the uniformly distributied load for this model. This frame one side carring 6000N load block and another side carrying 5400N load block i have doubt about how to apply udl load to this model. can any one help here??? this model right or wrong??
HI,
Select the nodes where you want to apply the load and divide the load by the this number,
For example, your load is 6000N and you want to apply load on say 6 nodes. Each node will have 1000N. You apply 1000N on each node.
