please suggest solution to the following error in linear static analysis
*** INTERNAL PROGRAMMING ERROR *** in file 'stnod8.F', at location # 284. **** ABORTING RUN DUE TO AN INTERNAL ERROR ****
Can you please share the entire out file?
i dont think im allowed to do that. could you please suggest possibilities for causes of the error?
Thank you
Hi Shiva Prasad,
India Technical support team will get in touch with you soon.
Thank you Prakash.
But is there any suggestion you can give!
@sivag93
Unfortunately, the available information is not sufficient to suggest or estimate what is causing the error.
