I would like to set up a topological analysis of a structural element so that Optistruct 'eliminates' material/volume until a stressed limit is reached.
In the topological analysis of a Carm.hm for example, I have the stress path and I can modify with a slider the density of the material, but I'd like to know If is possible the program to remove volume step by step until a minimum volume is requested that is solicited at most.
Can you tell me how to do it?
Thanks in advance
