'DLOAD 12 1.0 1 1.0 8 1.0 11' *** ERROR # 1000 *** in the input data: Incorrect data in field # 3.
Can someone tell how to work on this?
Please check the material property is assigned to the component or not?
Hello sir,
The following material properties were assigned, and the problem is arising
E=210000 Mpa
NU= 0.3
RHO= 7.87e-3 g/mm3
k=0.089W/mm’C
CP= 0.481 J/g/‘C
I have attached the files for your kind consideration.
PFA the updated fem file.
