Hello.
how can i look at solution progress in radioss implct?
it's not changing for 30 minutes=(
this issue abqs have solved for 10 minutes=)
Hi @Mrt
can you please share the .stat and .out file (engine and starter) from the run?
Hello @Prakash Pagadala.
i couldn't solve my issue in Radioss and i try it in Optistruct. it's so long in NNlnr analysis and i swiched linear, becouse i want to do optimization in HyperStudy.
if it be solved i will come back to solve this exercise in Radioss and i will take your help.
thanks a lot.
OK, /emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20'>
