Hello
I would like to perform a topology optimization of a material with different compression and tension stress limits.
The ratio of the limits is about 2-3.
It is not necessary to constraint exact values of the stresses.
Important is to consider the stress limit ratio. Then the standard procedure with minimize compliance and constrain volume would be ok.
Is there a good possibility how to set up such an optimization for optistruct?
Thank you!
