In Optistruct 2025.1, I'm trying to simulate a normal mode analysis of a box filled with air.
I created the acoustic cavity mesh and ACMODL card to define the fluid structure interface but it seems that the normal modes have been computed separately without interaction structure/fluid. I run 2 simulations: one with a steel box (210 GPa) and one with plastic box (10 GPa); the results are exactly the same so it means that there is not interaction structure/fluid.
Can you check the setup in the files I attached here below?
Thanks!
