Description: S-Concrete can't obtain a license via Altair One (managed/cloud licensing).
Product/Topic Name : First error: SOAP 1.1 fault SOAP-ENV:Client [no subcode] "End of file or no input: message transfer interrupted or timed out (5 sec max recv delay) (5 sec max send delay)" Detail: [no detail] Following Siemens KB000221457, I created the system environment variable ALM_HHWU_TIMEOUT = 90 and restarted the PC. The error then changed to: Error 522 fault detected [no subcode] "HTTP Error" Detail: error code: 522 The variable ALM_HHWU_USE_WININET is not set on this machine. When I try to access altairone.com, I get the "Altair One Production Update Notification" page saying the platform is under scheduled maintenance. Questions: 1. Is there an estimated date/time for Altair One licensing services to be restored? 2. Is there a temporary licensing alternative (e.g. a local/temporary license file) for customers with active licenses while the maintenance is ongoing?
