Altair Inspire 2026.1 crashes every time I select a STEP file through File > Open.
Environment:
- Windows 11 25H2, OS build 26200.9711
- Altair Inspire 2026.1
- Smart App Control is enabled
Diagnostic findings:
- Loading the bundled PyQt6 QtCore.pyd succeeds.
- Loading QtGui.pyd and QtWidgets.pyd fails with WinError 4551: “An Application Control policy has blocked this file.”
- The components are located under:
common\python\python3.10\win64\Lib\site-packages\PyQt6 - Repeated crash dumps show an access violation at hwui.dll+0x254564, in uiWidget::HasMouse(), called from hwfdmGuiManager::ImportModel().
- The Python Window remains blank when opened.
- Changing the interface language to English did not resolve the issue.
These findings suggest that failure to initialize the Python Window contributes to the crash when importing a model.
I have not disabled Smart App Control or modified the installed components. The component-loading test results are attached.
Could you please confirm:
- Whether a signed, Smart App Control-compatible installer or hotfix is available.
- Whether there is an officially supported workaround that keeps Smart App Control enabled.
- How I can privately provide crash dumps if needed.
Thank you.
