Hello, I have this problem with the license and I don't know how to resolve it. Can someone help me?
Please follow the procedure here if you need to use the Altair student edition -
it still doesn't work. I followed the procedure correctly, but when i add the license on the gui, an error message appears.
As you can see, my license hasn't been used yet.
Checking my account history on Altair One, I found out that my license key (LTP3T-RP6QJ-F8UR4-91QXN) status is set to "License Deactivated". Please re-issue a new Student Edition activation key or send an active altair_lic.dat file please
altair_lic.dat
HI,
The message license already exists in license store means the activation is already successful,
You could go to the location of the license in the license store, this is the path in the activation tab under the license store field, delete the .lic file there and then reactivate
