I am using Hypermesh Radioss 2026. If I model adhesive with solid apply with MAT 117 and Prop 43 Connect. The adhesive will be between steel (Shell) and composite (Shell). So how should I make contact between adhesive (solid) to steel (shell), adhesive (solid) to composite (shell). Also if I also want to see debonding effect on model, how should I do. Or is there have any tutorial video or model file for cohesive model with Radioss.
Thank You.
