how to export to solver
hello guys,
i generated a mesh using optistruct user interface on hyperworks student edition applying all needed constraints etc... i want to view the result of my simulation on hyperview i know that in order to do that i need the second step which is to solve my mesh using a solver but that's where am stuck i exported the solver deck file any idea on the next step ?
For doing an analysis you just need to go to the 'Analysis' page and click on the solver name you are using to run the analysis.
This will take you into a new window where you can select the location where you want to save the file. After that just click on 'OptiStruct'. This will run the solver.
Thankyou
