I have a model consisting of 3 stacked copper windings over 10 feet in diameter with 15 turns (~15 ft tall). Each winding is approximately 3.00 inches wide, making this a fairly large structure. Positioned slightly above and off-center from the windings is a 3-foot-diameter torus (corona ring) with a 0.25-inch-thick plate connecting the ring sections at the center.
Approximately 3.5 kA of current flows through the plate, but the magnetic field generated by the coil below induces additional current in the corona ring. In the field, the ring is heating significantly more than anticipated, and we need to accurately reproduce this behavior in FEKO so we can identify an effective solution.
After multiple iterations of both the geometry and the .cfx setup, we now have confidence that the current levels in the coils, as well as the current entering and leaving the corona ring/plate assembly, are correct. Because the current distribution in the windings appears accurate, we trust the magnetic field being generated by the helix. However, we do not have the same level of confidence in the induced currents and corresponding power-loss results within the corona ring. The loss distribution appears very "splotchy," meaning there are large localized differences that ultimately translate into unrealistic temperature gradients on copper surfaces. Given copper's high thermal conductivity, we would not expect to see such abrupt temperature variations.
To date, I have been running the simulation using MoM/SEP but have decided to investigate a FEM/MoM approach for comparison. One challenge I am encountering is the mesh density required to accurately capture skin effect at 19.6 kHz. The resulting FEM mesh exceeds 3 billion elements on the global coarse settingand requires substantially more memory (1.11 TBytes) than I've got.
My goal is to model the corona ring as an FEM body and compare the resulting current density and power-loss predictions against the surface-body model. Unfortunately, I have not yet been able to configure a FEM/MoM setup that runs successfully without generating errors.
I have uploaded the latest .cfx file. If anyone has suggestions for getting this model to run successfully in FEKO, I would greatly appreciate the guidance. Alternatively, if there is a method to export the magnetic field from FEKO and use another Altair product, such as SimLab, to analyze only the corona ring with the magnetic field applied as an excitation, I would be interested in exploring that approach as well.
Thank you,
Daniel
