I’m experiencing the same issue as other colleagues with PSIM installation. The installer reaches 100%, but the installation wizard never opens.
I’ve already tried all the solutions suggested in other discussions, including the recommended Java versions and running the installer with LAX_VM, but the issue persists.
Have you found a solution for this issue?
I also checked the %TEMP% folder and found the following error:
"GUI mode is not supported : Assistive Technology not found:
java.lang.NoClassDefFoundError: Could not initialize class com.zerog.util.ZGUtil
Any help would be greatly appreciated.
Thank you.
