I want to perform a topological optimization on a solid component.
I performed an initial analysis by meshing the entire solid and then selecting only a few mesh elements, to which I assigned a "non-design space" property.
Since the manual selection was too time-consuming and inaccurate, to correctly divide the mesh elements between "design space" and "non-design space," I divided the solid into two regions and then meshed them, ensuring mesh continuity using the "boolean-->combine (keep common interface)" command.
The strange thing is that with the first model, the optimization presents no problems. With the model configured this way, I can perform the linear static analysis, which gives me correct results. However, when I start the optimization, I get "ERROR 3423 - ERROR WITH CODE -71."
I'm sure the contact face of the solid part with the surface part and RBE2 elements are well defined.
