i have created a set of nodes in the model, but when i go to check the results in Optistruct the set doesn't appear. (i can't fine the set when i select results by SET)
Can someone help me please?
GT
In Hyperview while post processing set the load model with fem file and in load results use h3d file.
hi Rahul,
can you explane me how to do it please?
you are THE MASTER!!
Thank you
