I am running the same simulation in LTspice and PSIM (AC Analysis), but I am getting different results between the two simulations.
I would like to understand where this difference could come from. It is also possible that I have not fully understood how the Parameter Sweep block works in PSIM, so I would appreciate some clarification on how it should be configured and used.
Could you please help me identify the reason for the discrepancy and confirm whether my use of the Parameter Sweep block is correct?
Thank you for your help.
And here are my sweep parameters:
