Hello there,
I'm a user of Altair Flux and I wanted to test the SimLab software to see the differences.
I'm using the 2026.1 version of Altair SimLab.
I have a magnetostatic 3D model of a magnetic source (iron circuit with 2 non meshed coils), I'm using a symetry in all 3 planes.
So my idea was to do like in Flux and do a diffreent paths to evaluate B in the different axes to get B in function of the x position (same for y and z). I tried doing Node Path but they give me 0T (not the value intended). The only way I found to get a similar tool as the Flux path was to manualy chose points in the Query result and export the csv.
Is there a more automatic way ?
Thank you in advance
