UltraEdit: Single action to run your Jenner Alalytics, SAS or Altair SLC programs, previous method required two multi-keys.
see updated
https://github.com/rogerjdeangelis/utl-altair-slc-configuration-and-ultraedit-setup
In UltraEdit
Go to advanced > tool configuration. It is the 'hammer icon' and select configuration.
Menu Item Name: jnr
Command Line:cmd /c start /B C:\Progra~1\Jenner\jenner.exe %f -log "%p%n.log" -print "%p%n.lst" -work "d:/wpswrk"
Working directory: c:/slc
apply then ok
This is what I could not figure out earlier.
Menu Item Name 'jnr' is mapped to 'User Tool 1' in Advanced > Settings (the gear icon).
Go to advanced > settings (the gear icon) > toolbar/menu > key mappings
Select 'User Tool 1'
Existing Keys: (press alt-1)
Now you can run your program by striking just the multi-key alt-f1
