I am using Altair HyperWorks 2026 Student Edition on Windows 11.
The software was working previously, but now it fails to start due to licensing errors.
I have already tried:
- Deleting the
.altair_licensing folder. - Restarting the PC.
- Running the Altair License Utility as Administrator.
- Activating the license again.
- Confirmed that I have an active internet connection.
However, the problem persists.
The License Utility also shows:
"License already exists in license store."
The log contains the following errors:
Feature(s): GlobalZoneAP, HyperWorks, HWLauncher
Error Code: 9
Feature not found
Feature: HyperworksEDU
Error Code: 67
License activation cannot be verified, please check your internet connection and try again.
There is also:
System Error: No Auth Token in Managed Licensing config
Could you please check if my Student Edition license activation needs to be reset/deactivated on the Altair server so that I can activate it again?
If you need my Host ID or Activation Key, I can provide them privately.
Thank you.
