Hello there, I'm attempting the optimisation of a cube under stress with the following constraints at certain nodes on the structure, and I'm optimising the structure to minimise mass. The problem is that I can't seem to get the constraints right, some essential constrained nodes, which cannot be removed from the design keep disappearing.
I've tried constraining the displacement at these nodes to near 0, that doesn't work.
How do I prevent this
