Siemens RapidMiner SLC count the number of triangular faces in a convex hull mesh
Too long to post, see
https://github.com/rogerjdeangelis/siemens-rapidminer-slc-count-the-number-of-triangular-faces-in-a-convex-hull-mesh
The example consists of a diamond-shaped convex hull;
Count the number of triangular faces in a convex hull mesh
You should be able to apply this to more convex hull meshes
CONTENTS
1 Input xyz coords of diamond
2 R count faces
3 Pyhton count faces
