Altair slc running pspp the spss clone in linux within windows using ms wsl
Example: Run a regression height on weight using ubuntu linux.
Too long to post, see github
https://github.com/rogerjdeangelis/altair-slc-running-pspp-the-spss-clone-in-linux-within-windows-using-ms-wsl
There is a gui for pspp.
This opens up Opensource Linux SPSS to all programmers? If you have vanilla linux you can run the command line without slxc.
CONTENTS
1 preparation (installing pspp in linux)
2 windows: create slc dataset
3 windows: convert slc dataset to spss dataset
4 linux: run spss regression
5 run from linux commandline
6 drop down pspp macro
The most recent macro is at
https://github.com/rogerjdeangelis/utl-macros-used-in-many-of-rogerjdeangelis-repositories
