Hello, as I was trying to learn SRM motors from your example I came across this F2D_AN_SRMMotor_stepbystep file which I wanted to follow but the issue is the pdf is build around the older version of software and in the newer version of software I'm unable to find the Extensions tab from where I can load the overlay. Could you please help with it?
Hi Aradhya,
Thank you for contacting Forum.
Please close the sketcher using the yellow cross mark on top right corner and then it will allow you to open the overlay. Please find the image for reference.
Thanks
Karun
