Description: Hello I have an issue with Hypermesh 2024.1. The software freezes when exporting .fem model. The issue is linked to exporting NSML, although I believe I have it defined properly. If I set NSML as non-export, the export goes through. Do you know what could be the issue?
Product/Topic Name : Hypermesh 2024.1
*Note from Community Team - Once you receive a satisfactory answer on your question, kindly mark your answers as "Accepted" so it can help others with similar problems. Thanks.
