I am using the 2026 version of Motionview and now I want to do bidirectional coupling between MS and Optistruct. I saw that the 7022 case is about this, but when reproducing the 7022 case, I checked the flex body and did not see the functional source and Input Optistruct in the tutorial. Do I need to set anything for this? In addition, I set the environment variable as a system environment variable. What is the correct setting and have you successfully set any images?
