Description: When a set up the optimization, I select homogenized weave in the "Product" options for some plies and I also have some core but when I open the result .fem they all switched back to unidirectional. I was wondering if this affected my results ? Also, I read that if you select core for a ply it is not suppose to optimize it but in my results, it looks like it optimized my core material. Is there a way to make it so my core doesn't get optimized ?
Note : I know there is no core material in the exemple I sent, I did not find the .fem but I can fin it if you need
Product/Topic Name : I use Hypermesh2026.0 and Optistruct2026.0
*Note from Community Team - Once you receive a satisfactory answer on your question, kindly mark your answers as "Accepted" so it can help others with similar problems. Thanks.
