IN Multi axial fatigue life calculation, I have a constant load on Z axis at a different node and the Y direction load is changing from zero to 23000 in 0-5 s and constant till 55 s and 23000 to 0 in 55-60s at a different node and the cycle continues, how do the Hyperlife evaluate this loading at different points because I dont want the synchronous loading of Z and Y direction loads
