Hello everyone!
I'm examining a pneumatic spring suspension system using characteristic curves from the attached file "Airspring_data.asg" and following the path
I have a question:
The second to sixth columns correspond to the force values at each pressure in the Z_DATA list, for each spring height. How can I create a new data file from the parameters in this image into a new .asg file, and how can I verify that the force values are correct for the height and pressure at that time?
I'm not sure how to explain this in a technically correct way; I hope you can help me clarify it!
Thank you very much!
HuanRose
