I would like to ask whether PSIM provides a 4-terminal MOSFET model with separate Gate, Drain, Source, and Body (Bulk) terminals.
I have checked several MOSFET models available in PSIM, including the built-in MOSFET models, and they all appear to have only three terminals, with the body terminal internally connected to the source terminal.
So I would like to know if 4-terminal MOSFET model is available in PSIM?
If a 4-terminal MOSFET is not available, what is the recommended way to simulate a 4-terminal MOSFET in PSIM? For example, is there an equivalent device, a SPICE-based model, or another workaround that can be used to model body-bias effects and independent body-terminal connections?
Thank you for your help.
