Description: As the title suggests, is it possible to re-mesh a solid or shell part that has SPCs and RBE2s etc already attached? Alternatively, if this is not possible once the model has loads or constraints applied in this manner, is there an alternative way to approach modelling that is typically used to get around this issue?
My currently modelling approach has me deleting the elements and then manually having to reapply the RBEs Loads and constraints to a model that became linked to the mesh. This seems different to other software such as abaqus where re-seeding and remeshing a part does not require re application of loads and can be run again straight away. This makes mesh convergence analysis and quick tests extremely difficult to do for more complicated models. Surely there is a better way of doing this?
Product/Topic Name : Altair HyperMesh with OptiStruct Solver
